[GRASS-dev] [GRASS GIS] #2620: r.neighbours should offer to ignore centre value
GRASS GIS trac at osgeo.org
Mon Mar 16 07:21:24 PDT 2015
 Reporter:  marisn        |       Owner:  grass-dev@…
     Type:  enhancement   |      Status:  new
 Priority:  minor         |   Milestone:  7.0.1
Component:  Raster        |     Version:  7.0.0
 Keywords:  r.neighbours  |    Platform:  Unspecified
      Cpu:  Unspecified   |
Comment(by glynn):
 Replying to [comment:3 marisn]:
 > Second - it is not possible to use weights and circular neighbourhood at
 the same time (documentation states: "The -c flag and the weights
 parameter are mutually exclusive.")
 More accurately, it is not possible to use weight= and an automatically-
 generated mask (either the circular mask generated by -c or the Gaussian
 mask generated by gauss= or the square mask generated in the absence of
 any other applicable option). Nothing prevents weight= from being used to
 supply a circular mask.
 However, any automatically-generated mask (whether square, circular or
 Gaussian) is simply a short-cut whose behaviour could also be obtained by
 passing the appropriate mask via weight=. So the question isn't about
 what's possible, but what's possible without providing an explicit weights
 file.
 There's no end to the set of masks which could be generated internally;
 the only question is which ones are common enough to warrant a short-cut.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2620#comment:4>
