[GRASS-dev] 'utf8' codec can't decode byte 0xf6 in position 8: invalid start byte
Helmut Kudrnovsky hellik at web.de
Mon Mar 16 09:23:45 PDT 2015
> I tested winGRASS r64873, no problems with English locale, I switched to
German too, still no problems.
tested with
System Info
GRASS Version: 7.1.svn
GRASS SVN revision: 64873
Build date: 2015-03-16
Build platform: i686-pc-mingw32
GDAL: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
'utf8' codec can't decode error still there.
also tested with
System Info
GRASS Version: 7.0.0
GRASS SVN Revision: 64706
Erstellungsdatum: 2015-01-20
in the same OSGeo4W-stack, no problem there.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/utf8-codec-can-t-decode-byte-0xf6-in-position-8-invalid-start-byte-tp5193488p5193649.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
