[GRASS-dev] R in winGRASS
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Mar 16 15:16:06 PDT 2015
Hi Anna,
You need to define the path to R. I wrote a short explanation here:
https://pvanb.wordpress.com/2014/12/17/access-r-from-grass-gis-on-windows/
Hope that helps,
Paulo
On Mon, Mar 16, 2015 at 11:12 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Mon, Mar 16, 2015 at 6:05 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> Hi,
>> I am having troubles with running R in winGRASS. I installed R using this
>> tutorial:
>> http://www.r-bloggers.com/installing-rcpp-on-windows-7-for-r-and-c-integration/
>> In normal windows command line, it works. In GRASS session, I get this
>> when running R:
>> C:\Users\akratoc>R
>> '"\R.exe"' is not recognized as an internal or external command,
>> operable program or batch file.
>> Any idea?
> I just read on the wiki, you have to install R first, then GRASS, so I
> reinstalled GRASS, but still no success.
>> Thank you
>> Anna
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150316/65e8f0c1/attachment.html>
