[GRASS-dev] R in winGRASS
Anna Petrášová
kratochanna at gmail.com
Tue Mar 17 12:34:45 PDT 2015
I made it work, I reinstalled it and it works now. The first time, I
haven't installed it in Program Files because I read somewhere that spaces
in path will cause problems for R. Now it's in Program Files and so far
everything is running.
Is it necessary to install it to Program Files?
Thanks for your help.
On Tue, Mar 17, 2015 at 10:00 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Anna Petrášová wrote
> > On Mon, Mar 16, 2015 at 6:05 PM, Anna Petrášová <
> > kratochanna@
> > wrote:
> >> Hi,
> >> I am having troubles with running R in winGRASS. I installed R using
> this
> >> tutorial:
> http://www.r-bloggers.com/installing-rcpp-on-windows-7-for-r-and-c-integration/
> >> In normal windows command line, it works. In GRASS session, I get this
> >> when running R:
> >> C:\Users\akratoc>R
> >> '"\R.exe"' is not recognized as an internal or external command,
> >> operable program or batch file.
> >> Any idea?
> > I just read on the wiki, you have to install R first, then GRASS, so I
> > reinstalled GRASS, but still no success.
> >> Thank you
> >> Anna
> > grass-dev mailing list
> > grass-dev at .osgeo
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> related see: http://trac.osgeo.org/osgeo4w/ticket/413#comment:5
> I've prepared the R batch files for including in OSGeo4W; let's hope it
> will
> uploaded.
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/R-in-winGRASS-tp5193729p5193900.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150317/d438a494/attachment.html>
