[GRASS-dev] Linke turbidity in r.sun.daily
Nikos Alexandris
nik at nikosalexandris.net
Fri Mar 20 13:41:42 PDT 2015
On 20.03.2015 22:27, Vaclav Petras wrote:
> Hi Nikos,
> On Fri, Mar 20, 2015 at 4:07 PM, Nikos Alexandris
> <nik at nikosalexandris.net>
> wrote:
>> Hi list, @Anna, @Vaclac
>> is there interest to add support for the Linke Turbidity (as an
>> input) to
>> the r.sun.daily script?
>> there certainly is interest is that (although not from me :-). I
>> just
> don't have time to do it. You might be able to add it there. I can do
> the
> code review then.
On-sight, looks as easy as adding another parameter update along with
the necessary additions which an update like this will require to the
rest of the script.
If I retouch the script, may I replace globally, wherever applicable,
the "%s" % var stuff with '{s}'.format(s=var} ?
Nikos
