[GRASS-dev] QGIS GRASS Plugin Upgrade Crowdfunding
Vaclav Petras
wenzeslaus at gmail.com
Tue Mar 24 07:54:33 PDT 2015
On Tue, Mar 24, 2015 at 2:00 AM, Pietro <peter.zamb at gmail.com> wrote:
> Hi Radim,
> together with Francesco Geri, last week we started to write a first
> draft that generate the GUI for the GRASS module dynamically (based on
> the xml generated with: --interface-description), so far it is based
> on grass7 but should work also on grass6 (not tested, should be enough
> to backport the pygrass.modules.Module class).
> Hi Pietro and Francesco,
this sounds good. Are you speaking about QGIS GUI (in Python) generated
from --interface-description? Do you think it would be possible to write it
in a way which would be GUI framework independent so that it is usable in
both GRASS and QGIS? The GUIs for modules in GRASS are quite good now but
the code should be rewritten and this would be a great way how to get this
new implementation.
Vaclav
> Best regards
> Pietro
> On Mon, Mar 23, 2015 at 7:56 PM, Radim Blazek <radim.blazek at gmail.com>
> wrote:
> > Hi all,
> > I have finally launched the crowdfunding campaign to support the GRASS
> > plugin upgrade. Briefly, it covers upgrade to GRASS 7, browser
> > integration, drag-and-drop import and new vector editing. All the
> > details are available here:
> > http://www.gissula.eu/qgis-grass-plugin-crowdfunding/
> > Please propagate this info to all relevant channels, national mailing
> lists etc.
> > Radim
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150324/e61210d5/attachment.html>
