[GRASS-dev] GSOC project proposal: GUI plugin system for GRASS GIS
jyoti misra
jyotimisra.99 at gmail.com
Wed Mar 25 07:51:59 PDT 2015
I was looking into the files you sent and I think I am going in the right
direction. I will try to complete the task as soon as possible.
As for the enhancement I was thinking of creating a search box in our
current structure that takes the users query and redirects it to the result
page of espg.io with the query. For e.g. if I search India redirect URL
will be http://epsg.io/?q=india.
But where exactly do I need to make the changes? Please help me with that.
Regards
Jyoti
On Wed, Mar 25, 2015 at 6:59 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Wed, Mar 25, 2015 at 2:20 AM, jyoti misra <jyotimisra.99 at gmail.com>
> wrote:
>> I was looking into the Bug: "Quotes not preserved in command after
>> pressing enter in GUI command console" and tried it out on my machine. I
>> was trying to fix it and I think most probably it's some problem with regex
>> search which is deleting the quotes from the command.
>> I was looking into the code for fixing the bug but couldn't find the
>> relevant file to change. Could you please guide me with that.
>> It will be probably one of those:
> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/core/gconsole.py
> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/core/gcmd.py
> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/gui_core/prompt.py
> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/gui_core/pystc.py
> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/gui_core/goutput.py
> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/lmgr/frame.py
>> Also for the enhancement: "Button, documentation and perhaps something
>> more interactive for finding EPSG codes online rather then in GRASS GIS
>> list" I was thinking of more interactive process of using EPSG -
>> 1. We can merge epsg.io code into our existing structure. http://epsg.io/
> This is not desirable. Although there might be some places to get inspired
> from what the system offers while GRASS system lacks.
>> 2. We can add a button that will redirect users to epsg.io
> This is the most simple and straightforward way how to implement this.
> Button can just open a web browser. There is a standard way in wxPython to
> do this.
>> I would like to have your suggestions on the same
> Alternative is to somehow use their URLs (or API if there is some) to do
> some search or show additional information about the projection. This needs
> a more detailed analysis of the problem. The button mentioned before would
> be a good start. Even with a simple button, the opened URL could also
> include something like currently searched URL.
> Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150325/f3f4da8f/attachment-0001.html>
