[GRASS-dev] [GRASS GIS] #2637: Get direction raster in clockwise degrees starting from the North
trac at osgeo.org
Thu Mar 26 02:34:36 PDT 2015
Reporter: cgravelm | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.1
Component: Raster | Version: 7.0.0
Keywords: | Platform: MacOSX
Cpu: Unspecified |
Comment(by hellik):
Replying to [ticket:2637 cgravelm]:
> I have been looking for a way to create a raster direction map using a
DEM in GRASS (I am currently using the stable 7.0.0 version). So far, the
3 different scripts that do so (r.param.scale, r.shaded.aspect, and
r.fill.dir) assume that 0 is at the East and count counterclockwise from
there. The only way I can create a clockwise direction map with 0 at the
North is to use the format "agnps" in r.fill.dir. However, this creates a
map with directions ranging from 0 (equivalent to 0) to 8 (equivalent to
360 degrees), which can be easily transformed into a 0-360 scale, but
lacks precision.
> Would it be possible to add a flag in one of those scripts to create
maps in degrees that have 0 to the North, 90 to the East and so forth? It
would make it easier to integrate GRASS rasters to agent-based models.
have a look e.g. at [http://trac.osgeo.org/grass/browser/grass-
addons/grass7/raster/r.northerness.easterness/r.northerness.easterness.py#L61
aspect angles from cartesian (GRASS default) to compass angles] for a
r.mapcalc calculation
Ticket URL: <http://trac.osgeo.org/grass/ticket/2637#comment:2>
