[GRASS-dev] [GRASS GIS] #2523: wxGUI digitiser - GRASS 7.0.0beta4 / persists in 7.1.svn (r64690M) (was: wxGUI digitiser - GRASS 7.0.0beta4)
GRASS GIS trac at osgeo.org
Thu Mar 26 07:13:05 PDT 2015
 Reporter:  jeir             |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  7.1.0
Component:  wxGUI            |     Version:  svn-trunk
 Keywords:  digitizer, .gxw  |    Platform:  MacOSX
      Cpu:  OSX/Intel        |
Changes (by jeir):
  * keywords:  digitizer => digitizer, .gxw
  * version:  svn-releasebranch70 => svn-trunk
  * milestone:  7.0.0 => 7.1.0
Comment:
 I have come across the following irregular/erratic slightly annoying
 behaviour of the GRASS 7 wxgui, following up this ticket.
 Environment
 [Mac OS X 10.10.2]
 [Mac OS X 10.7.5]
 [GRASS GIS 7.1.svn (r64690M)]
 Point 1 (Only applies to Mac OS X 10.7.5, as far as I can tell)
 Open GRASS in nc_spm_08_grass7, User1
 g.copy vector=roadsmajor at PERMANENT,test_roadsmajor
 Add vector map layer
 test_roadsmajor is displayed - On GRASS GIS 7.1.svn Map Display: 1 -
 Select  Vector digitizer on right hand button-palette
 Left hand layer select button - palette has one option: New vector map
 On Layer Manager window, switch to roadsmajor at PERMANENT
 On Map Display Window - click on Layer select button-palette, voila:
 test_roadsmajor layer is a visible option. Selecting it activates
 digitizer on that map
 Problem: The layer button-palette  options do not get updated, when the
 Add layer option is used
 Point 2 (Applies to both Mac OS X 10.7.5 and Mac OS X 10.10.2)
 Same session
 Resize (enlarge) GRASS GIS 7.1.svn Map Display: 1 - Location:
 nc_spm_08_grass7 at user1 window
 File-Workspace-Save as- _test.gxw
 EXIT GRASS GIS and QUIT GRASS GIS 7.1.svn Map Display: 1 - Location:
 Start GRASS GIS - same location and mapset
 File-Workspace-Open- _test.gxw
 The GRASS GIS 7.1.svn Map Display: 1 - Location: nc_spm_08_grass7 at user1
 window opens up in Save as size, but the test_roadsmajor map is not zoomed
 to the window size, rather it is displayed in the default display window
 size. One resize of the window updates the zoom to fuill current (saved)
 window size.
 Problem: The map is not zoomed to window size as the Workspace file is
 opened.
 Point 3 (Applies to both Mac OS X 10.7.5 and Mac OS X 10.10.2)
 After opening the Vector digitizer, the Quit digitizer button is sometimes
 not visible until the window has been resized. This seems to be
 independent of the size of the window at the moment the digitizer is
 activated.
 Problem: Lower row on the Map Display window is not updated when the
 Vector digitizer is activated, even though the window is wide enough.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2523#comment:8>
