[GRASS-dev] Compute mahalanobis distance using Scipy
Paulo van Breugel
p.vanbreugel at gmail.com
Fri May 1 05:48:34 PDT 2015
Hi Pietro
I would just like to check if you had a change to look at the problem
described in http://trac.osgeo.org/grass/ticket/2629?
Cheers
Paulo
On 16-03-15 22:01, Paulo van Breugel wrote:
> Great, I'll do that
> On Mon, Mar 16, 2015 at 9:56 PM, Pietro <peter.zamb at gmail.com
> <mailto:peter.zamb at gmail.com>> wrote:
> Hi Paulo,
> On Mon, Mar 16, 2015 at 9:23 PM, Paulo van Breugel
> >> Alternatively, it might indicate an issue in the PyGrass library; that
> >> code is relatively new.
> > OK, hopefully the PyGrass gurus can have a look at it.
> Ofcourse I will look into it, but since I need two/three weeks, may be
> could a good idea to open a ticket on track, just to not forget this
> problem.
> Thank you for reporting this.
> Pietro
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150501/68307d16/attachment.html>
