[GRASS-dev] GRASS7 GUI error on Fedora 22 (beta)
Vaclav Petras
wenzeslaus at gmail.com
Mon May 4 14:04:01 PDT 2015
On Mon, May 4, 2015 at 4:55 PM, Pietro <peter.zamb at gmail.com> wrote:
> Dear All,
> I'm trying to make a virtual machine with GRASS7 on Fedora 22 (only
> grass64 is available so far), I didn't have any particular problem
> configuring with:
> ./configure \
> --with-cxx \
> --with-gdal=/usr/bin/gdal-config \
> --with-proj --with-proj-share=/usr/share/proj \
> --with-sqlite \
> --with-nls \
> --with-wxwidgets=/usr/bin/wx-config \
> --with-fftw \
> --with-python=/usr/bin/python-config \
> --with-freetype --with-freetype-includes=/usr/include/freetype2 \
> --enable-largefile \
> --without-odbc
> and then compiling...
> but when I start GRASS I got this Error:
> $ grass71
> Fatal Error: Mismatch between the program and library build versions
> detected.
> The library used 3.0 (wchar_t,compiler with C++ ABI 1008,wx
> containers,compatible with 2.8),
> and wxPython used 3.0 (wchar_t,compiler with C++ ABI 1002,wx
> containers,compatible with 2.8).
> ERROR: Invalid return code from GUI startup script.
> Please advise GRASS developers of this error.
> Exiting...
> Any ideas?
Nothing in particular, but you can try to `import wx` in Python command
line inside and outside of GRASS session to see what happens.
Vaclav
> Pietro
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150504/9edbd935/attachment.html>
