[GRASS-dev] g.remove usage syntax
Martin Landa landa.martin at gmail.com
Tue May 5 03:30:48 PDT 2015
2015-05-05 12:28 GMT+02:00 Margherita Di Leo <diregola at gmail.com>:
> being name one of the two options (name, pat) that could be identifier= or
> something better. In this case, it would be possible to type the former
> command or the extended form:
> g.remove type=vect identifier=name name=foo -f
> or
> g.remove type=vect identifier=pattern name="f*" -f
> (g.remove vect pat "f*" -f)
> what do you think?
no idea, in any case it's issue for GRASS 8. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
