[GRASS-dev] Testing an add-on from sandbox before moving to grass-addons
Nikos Alexandris nik at nikosalexandris.net
Tue May 5 04:42:36 PDT 2015
Nikos Alexandris:
> > I am trying to not mess-up anything in grass-addons.  Hence, I first
> > uploaded the i.fusion.hpf script in sandbox:
> > <https://svn.osgeo.org/grass/sandbox/alexandris/i.fusion.hpf/>.
> > Is it possible to get the add-on from the sandox, via g.extension, under
> > Windows?  I have no easy access to a windows machine with GRASS and co.
Martin:
> it's not possible, to enable installing this extension via
> g.extension, you need to move this extension to `grass7/imagery`.
Thanks Martin.  Is grass7/imagery the safest place to move into?  Just
to confirm.
Nikos
