[GRASS-dev] Testing an add-on from sandbox before moving to grass-addons
Nikos Alexandris
nik at nikosalexandris.net
Tue May 5 05:41:21 PDT 2015
* Martin Landa <landa.martin at gmail.com> [2015-05-05 13:41:32 +0200]:
> 2015-05-05 13:42 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> >> it's not possible, to enable installing this extension via
> >> g.extension, you need to move this extension to `grass7/imagery`.
> > Thanks Martin. Is grass7/imagery the safest place to move into? Just
> > to confirm.
> yes, as grass7/imagery/i.fusion.hpf. Use `svn move` to do this job. Martin
Noted, thank you for your time.
Nikos
