[GRASS-dev] [GRASS GIS] #2669: v.net.iso: different results depending on direction
trac at osgeo.org
Wed May 6 02:54:23 PDT 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Vector | Version: svn-trunk
Keywords: network v.net.iso direction cost | CPU: Unspecified
Platform: Unspecified |
Testing v.net.* modules to see whether the number of vertices in lines
makes a difference for results (for info: it doesn't), I came upon a weird
bug.
I digitized three +/- parallel lines (with different number of vertices)
and start points at more or less similar positions on these lines.
Then:
v.net test_lines points=test_points op=connect thresh=500 out=network
v.db.update network col=cost qcol="length/(speed*1000/60)"
v.net.iso input=network at isochrones output=isos center_cats=1-3
costs=5,10,15,20,25,30,35,40 arc_column=cost
So cost is the same in both directions. However, the result I get is very
different depending on the direction from the starting point (cf attached
image - numbers are the categories from v.net.iso, blue circles are the
start points).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2669>
