[GRASS-dev] [GRASS GIS] #2349: CELL raster format: make ZLIB level 3 standard compression instead of RLE
trac at osgeo.org
Wed May 6 03:06:14 PDT 2015
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: critical | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: compression, r.compress, null
CPU: Unspecified | Platform: All
Comment (by neteler):
Thanks for the patch. I applied it to my local copy of relbr70. Testing
with this map
GRASS 7.0.1svn (eu_laea):~/releasebranch_7_0 > r.info -g eu_dem25_rand100k
north=6000000
south=1000000
east=8000000
west=2000000
nsres=25
ewres=25
rows=200000
cols=240000
cells=48000000000
datatype=FCELL
ncats=0
I created a new one using the 100k random points FCELL map sampled earlier
from the EU 25m DEM:
r.mapcalc "new = eu_dem25_rand100k"
Using the patch, I see that a NULL file is no longer generated.
Expectedly, since the other modules are not updated yet, I cannot read
that map:
GRASS 7.0.1svn (eu_laea):~/releasebranch_7_0 > r.univar new
ERROR: Raster map <new at PERMANENT>: format field in header file invalid
Next test with INT conversion:
GRASS 7.0.1svn (eu_laea):~/releasebranch_7_0 > r.mapcalc "new_int =
round(eu_dem25_rand100k)"
GRASS 7.0.1svn (eu_laea):~/releasebranch_7_0 > r.univar new_int
0%
... the map is readable and comes with the NULL file but that's as before
6GB big (so no compression occurred).
Are my tests wrong or am I missing anything else?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2349#comment:19>
