[GRASS-dev] Error launching wxGUI in 7.0.1 r65194
Eric Patton
epatton at nrcan.gc.ca
Wed May 6 12:02:30 PDT 2015
I am using a fresh checkout of Grass 7.0.1 r65194, and it compiled with no errors
(error.log is empty).
Machine details:
uname -a Linux W5-DAR-EPATTON 3.13.0-24-generic #47-Ubuntu SMP Fri May 2
23:30:00 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
File "/usr/local/grass-7.0.1svn/gui/wxpython/wxgui.py", line 142, in <module> sys.exit(main())
File "/usr/local/grass-7.0.1svn/gui/wxpython/wxgui.py", line 134, in main app = GMApp(workspaceFile)
File "/usr/local/grass-7.0.1svn/gui/wxpython/wxgui.py", line 49, in __init__ wx.App.__init__(self, False)
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7981, in __init__ self._BootstrapApp()
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7555, in _BootstrapApp return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "/usr/local/grass-7.0.1svn/gui/wxpython/wxgui.py", line 83, in OnInit workspace = self.workspaceFile)
File "/usr/local/grass-7.0.1svn/gui/wxpython/lmgr/frame.py", line 121, in __init__ self._moduleTreeBuilder = LayerManagerModuleTree()
File "/usr/local/grass-7.0.1svn/gui/wxpython/lmgr/menudata.py", line 62, in __init__ MenuTreeModelBuilder.__init__(self, filename, expandAddons=expandAddons)
File "/usr/local/grass-7.0.1svn/gui/wxpython/core/menutree.py", line 66, in __init__ expAddons(xmlTree)
File "/usr/local/grass-7.0.1svn/gui/wxpython/core/toolboxes.py", line 346, in expandAddons _expandRuntimeModules(root, loadMetadata=True)
File "/usr/local/grass-7.0.1svn/gui/wxpython/core/toolboxes.py", line 596, in _expandRuntimeModules desc, keywords = _loadMetadata(name)
File "/usr/local/grass-7.0.1svn/gui/wxpython/core/toolboxes.py", line 629, in _loadMetadata task = gtask.parse_interface(module)
File "/usr/local/grass-7.0.1svn/etc/python/grass/script/task.py", line 509, in parse_interface tree = etree.fromstring(get_interface_description(name))
File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1300, in XML parser.feed(text)
File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1642, in feed self._raiseerror(v)
File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1506, in _raiseerror raise err xml.etree.ElementTree.ParseError: not well-formed (invalid token): line 17, column 19
Any ideas on what is going wrong?
~ Eric.
