[GRASS-dev] [GRASS GIS] #2671: r.surf.idw won't make interpolation
trac at osgeo.org
Sat May 9 06:00:50 PDT 2015
Reporter: kuszinger | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Keywords: interpolation, e.surf.idw | CPU: x86-64
Platform: Linux |
However '''r.surf.idw''' won't make the interpolation for my dataset, I
tested on NC sample dataset where it was ok. ??
I was not able to reproduce it with any other dataset but mine. I've
created a cut of my data and accessible in the next comment.
Projection: UTM 48N / WGS84 (on the area of Cambodia)
+proj=utm
+no_defs
+zone=48
+a=6378137
+rf=298.257223563
+towgs84=0.000,0.000,0.000
+to_meter=1
Symptom:
r.surf.idw runs for the whole coverage. No error message displayed. When
finished, the target raster map is the very same as the input was.
Command run:
''r.surf.idw --overwrite input=debugfrom at lidar output=debugto npoints=7
Purpose: generate a continuous surface from a very sparse set of points on
the map.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2671>
