[GRASS-dev] [GRASS GIS] #2671: r.surf.idw won't make interpolation
trac at osgeo.org
Sun May 10 10:20:38 PDT 2015
Reporter: kuszinger | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: interpolation, r.surf.idw
CPU: x86-64 | Platform: Linux
Comment (by kuszinger):
'''NC''': used '''elevation''', the whole, set g.region res=5 so the
target dataset is bigger, it ran well with good results. Anyway, the
source dataset is not sparse. I''' rerun on the NC elevation and making it
sparse with random nulls, ok?'''
'''6.4: yes, worked like charm''', less than 2GB memory usage (same
machine same everything).
One more extra: while the above debug region is:
projection: 1 (UTM)
zone: 48
datum: wgs84
ellipsoid: wgs84
north: 1529314.78008
south: 1528778.59005
west: 448590.883652
east: 449308.347889
nsres: 0.19999628
ewres: 0.20001791
rows: 2681
cols: 3587
cells: 9616747
the whole map which was successfully interpolated in 6.4 was:
projection: 1 (UTM)
zone: 48
datum: wgs84
ellipsoid: wgs84
north: 1525100
south: 1522400
west: 449885
east: 453027
nsres: 0.2
ewres: 0.2
rows: 13500
cols: 15710
cells: 212085000
so, my packed sample is only a cut of which was successfully processed in
6.4
Anyway, I try NC with its modified eleveation and coome back with the
results...
thanks
Ticket URL: <http://trac.osgeo.org/grass/ticket/2671#comment:4>
