[GRASS-dev] g.region zoom?
Moritz Lennert
mlennert at club.worldonline.be
Mon May 11 23:28:27 PDT 2015
On 11/05/15 23:48, Anna Petrášová wrote:
> On Mon, May 11, 2015 at 5:01 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
> On Mon, May 11, 2015 at 5:58 PM, Anna Petrášová
> <kratochanna at gmail.com <mailto:kratochanna at gmail.com>> wrote:
> Hi,
> I just realized how g.region zoom actually works and I am
> wondering if it is supposed to be obvious. I always thought it
> will set the region to the raster map minimum bounding box, but
> it takes current region and only shrinks it. The behavior is
> written in the manual (I eventually realized), but it doesn't
> strike me as particularly useful.
> What for example if you want to restrict calculations to the region
> defined by the non-null values of a particular map that has a
> different resolution than the maps you are using in your calculations?
> I am not concerned with resolution but extent. I was mostly confused
> from the case when I have region smaller than the extent of the raster
> (from previous computation) and then I expected g.region zoom to set
> the region on the whole raster extent, but instead it shrinks even more
> if there are nulls or it stays the same. So the result of the g.region
> zoom depends on you previous region settings which was unexpected for me.
> At least I would suggest to change the g.region zoom behavior in
> the GUI -> right click on layer -> Set computational region from
> selected map (ignore NULLS) to:
> g.region raster=map zoom=map
> That does indeed seems the more obvious / intuitive behaviour to me
> I will do that, thanks!
I'm always tempted to actually propose to remove that option totally
from the right-click menu as I find that it often confuses users (maybe
the description is not clear enough), but I agree that if we want to
leave it, then your version sounds more intuitive.
Moritz
