[GRASS-dev] inconsistency between G_OPT_V_INPUT and G_OPT_R_INPUT
Pietro peter.zamb at gmail.com
Wed May 13 06:47:06 PDT 2015
Hi Martin,
On Wed, May 13, 2015 at 11:08 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2015-05-13 8:03 GMT+02:00 Pietro <peter.zamb at gmail.com>:
>> #% description: Name of vector map with interested segments of rivers
> <- label
Therefore I should use label instead of description, something like:
#!/usr/bin/env python
# -- coding: utf-8 --
#%module
#% description: Test
#% keywords: test
#%end
#%option G_OPT_R_INPUT
#% key: discharge
#% label: Name of river discharge [m3/s]
#% required: yes
#%end
#%option G_OPT_V_INPUT
#% key: river
#% label: Name of vector map with interested segments of rivers
#% required: yes
#%end
from __future__ import print_function
import sys
# import grass libraries
from grass.script import core as gcore
def main(opts, flgs):
    print(opts, flgs)
if __name__ == "__main__":
    options, flags = gcore.parser()
    sys.exit(main(options, flags))
The GUI is now fine and the command output looks:
{{{$ r.example --h
Description:
 Test
Keywords:
 test
Usage:
 r.example discharge=name river=name [--help] [--verbose] [--quiet]
   [--ui]
Flags:
 --h   Print usage summary
 --v   Verbose module output
 --q   Quiet module output
 --ui  Force launching GUI dialog
Parameters:
  discharge   Name of river discharge [m3/s]
               Name of input raster map
      river   Name of vector map with interested segments of rivers
               Or data source for direct OGR access
>> As you can see the description of the parameter add the default
>> description set in G_OPT_V_INPUT and in a new line the description
>> added manually in the definition of the module parameters. Instead the
>> G_OPT_R_INPUT shows only the description set manually.
> right, G_OPT_V_INPUT has defined both label and description [1]. This
> the source of inconsistency. There are more standard options which
> defines both label and description.
Do you think this inconsistency should be fix, or just reported
somewhere on a Wiki page?
All the best.
Pietro
