[GRASS-dev] Linke turbidity in r.sun.daily
Nikos Alexandris nik at nikosalexandris.net
Fri May 15 13:42:54 PDT 2015
* Nikos Alexandris <nik at nikosalexandris.net> [2015-05-15 23:18:18 +0300]:
> * Nikos Alexandris <nik at nikosalexandris.net> [2015-05-15 16:34:38 +0300]:
> > * Vaclav Petras <wenzeslaus at gmail.com> [2015-05-15 08:41:17 -0400]:
> > > On Fri, May 15, 2015 at 8:10 AM, Nikos Alexandris <nik at nikosalexandris.net>
> > > wrote:
> > > > I have another use-case, hence another update to the script.  Does
> > > > anyone care to have a look at the proposed diff (really a quick hack, no
> > > > extensive testing done but it works for me).
> > > Looks good except for computing the slope and aspect on the fly.
> > > r.slope.aspect runs twice once for slope, once for aspect. With current
> > > code, it actually looks that there might be some override issues. Try
> > > harder to preserve current mechanism where one r.slope.aspect call is build
> > > according to missing inputs. You need to change the if conditions somehow.
> > > (Only reading the diff.)
> > Known issue, thanks for reading Vaclav.  Will rework another day on it.
> I am not getting easily away from this script.
> I want to check whether a strds already exists, and if it does, don't
> re-create it (overwrite it). Rather, register follow-up maps in the existing strds.
> Makes sense?  This need rose from the attempt to loop r.sun.daily over
> different monthly Linke Turbitidy values. Something like the following:
correction:
> for LINE in `cat monthly_linke_map_start_day_end_day.csv` ;do set --
> $(echo ${LINE} |tr "|" " ") && r.sun.daily elevation=srtm4 at PERMANENT
> aspect_value=0 slope_value=0.0 albedo=albedo at albedo linke=$1
> start_day=$2 end_day=$3 glob_rad_basename=global_rad_zero
> insol_time_basename=insol_time beam_rad_basename=beam_rad_zero
> diff_rad_basename=diff_rad_zero --o -t ;done
Like this,
> ...each subsequent call of creating a strds, will overwrite if
> it exists. Hence, only the maps involved in the last run of the above
> loop will appear in the strds.
If using different names for output maps after each loop, multiple strds are created,
naturally, which is unwanted.
Nikos
