[GRASS-dev] [GRASS GIS] #2349: CELL raster format: make ZLIB level 3 standard compression instead of RLE
trac at osgeo.org
Fri May 15 21:53:07 PDT 2015
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: critical | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: compression, r.compress, null
CPU: Unspecified | Platform: All
Comment (by glynn):
Replying to [comment:21 neteler]:
> I tried again but don't see a difference in the NULL file size:
Check that the patch applied successfully, that compilation was
successful, and that r.mapcalc is using the new libgrass_raster.so, not
e.g. an installed version.
The first two can be confirmed by running "strings" on the library and
confirming that GRASS_COMPRESS_NULLS appears in the output. The last can
be confirmed with e.g.
ldd $(which r.mapcalc)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2349#comment:22>
