[GRASS-dev] new rendering
Martin Landa
landa.martin at gmail.com
Sat May 16 09:22:26 PDT 2015
2015-05-15 5:05 GMT+02:00 Anna Petrášová <kratochanna at gmail.com>:
> - MapSwipe doesn't work - due to calls layer.Render() but it requires
> parameter environment. There are actually several of these calls in
> render.py, I was not sure what to do, maybe some of them can be just
> removed.
attempt to fix it in r65255. There is still issue with multiple
calling g.pnmcomp. MapSwipe has also issue when starting from command
line with `first/second` parameters, map display is not correctly
updated after launching.
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
