[GRASS-dev] [GRASS-SVN] r65264 - grass/trunk/lib/cairodriver
Martin Landa landa.martin at gmail.com
Mon May 18 06:49:32 PDT 2015
2015-05-18 15:46 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
>> 2015-05-18 15:36 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
>> >> +<div class="code"><pre>
>> >> +export GRASS_RENDER_IMMEDIATE=cairo
>> >> +export GRASS_RENDER_FILE=vectormap.svg
>> >> +g.region vector=roadsmajor
>> >> +d.vect map=roadsmajor -c
>> >> +</pre></div>
>> > The syntax is not really nice. Is it possible to replace it with
>> > something
>> > else like d.mon? Or is this the best interface we have?
>> I am not sure what you mean, but d.mon syntax could be:
>> d.mon cairo out=vectormap.svg
>> d.mon -r
> I think this is exactly what I mean. Any reason for using the variables
> instead of d.mon?
I would say that it make sense to document the both ways
(environmental variables on display driver page and d.mon syntax on
it's own page), probably we could add note about d.mon to cairo driver
manual.
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
