[GRASS-dev] r.proj produces null map
Martin Landa landa.martin at gmail.com
Mon May 18 08:18:40 PDT 2015
2015-05-18 17:16 GMT+02:00 Margherita Di Leo <diregola at gmail.com>:
> on G7, I made several tentatives trying to reproject raster maps using
> r.proj, it doesn't yield error but the map is completely empty (null). I
> made several tentatives on several maps, then also exported and reprojected
> with gdalwarp, to test if the problem was related to the data. Can someone
> reproduce this, before i open a ticket.
are you sure that you have set in destination location region
correctly? See r.proj's -g flag.
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
