[GRASS-dev] Error launching wxGUI in 7.0.1 r65194
Eric Patton epatton at nrcan.gc.ca
Tue May 19 08:24:24 PDT 2015
Hello,
I updated my svn and rebuilt, again without errors, but launching the GUI
caused the same problem. Instead, I deleted the ~/.grass7 directory, and
rebuilt, and it seemed to solve the problem. I suspect you are right that it
was an issue caused by some addon that I had previously loaded.
~ Eric.
> Please do lsb_release -a.
> Then check if there is something in ~/.grass7/toolboxes/. (There could be
> something in case you experimented with toolboxes.)
> Also look back in the compilation output you will find there section where
> there are some compilations of gui/wxpython code to .pyc. Then there should
> be parts which are comping toolboxes. Compilation holds there for a while
> with line ending with something like module_items.xml. Checking this might
> be useful in case there is something which should be an error but it is not.
> I don't have better idea now (I just checked release branch and it works
> for me).
> Vaclav
