[GRASS-dev] [GRASS GIS] #2680: d.mon: input file has incorrect dimensions
GRASS GIS trac at osgeo.org
Tue May 19 14:36:23 PDT 2015
 Reporter:  annakrat     |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.0.1
Component:  Display      |    Version:  svn-trunk
 Keywords:  d.mon        |        CPU:  Unspecified
 Platform:  Unspecified  |
 I found two related problems with current d.mon.
 1. When I resize the d.mon window, and run a d.* command, I get error:
 ERROR: Cairo: input file has incorrect dimensions: expected: 640x480 got:
        861x480
 2. On Windows, this is even more interesting. I open wx0 monitor, run for
 example d.rast, so far good, but the second d command fails (but the
 window is still the same as when it opened):
        656x519
   These dimensions in the error are the same when running d.mon with or
 without -x.
 Tested on r65288 on Linux and r65276 build on Windows.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2680>
