[GRASS-dev] [GRASS GIS] #2677: mapswipe add raster map doesn't work with wxPython 3
GRASS GIS trac at osgeo.org
Wed May 20 10:09:58 PDT 2015
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  critical     |  Milestone:  7.1.0
 Component:  wxGUI        |    Version:  unspecified
Resolution:               |   Keywords:  mapswipe
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by wenzeslaus):
 I can confirm the issues with status bar. My ends in half of the window.
 After resize, it spreads to the right positions but the select/choice box
 text is not fully visible. (We can't do much about this I think. Perhaps
 using our custom solution to get rich statusbars/bottom bars would be
 better (we are not using statusbar only for status)).
 This might be also unrelated but when I run:
 g.gui.mapswipe first=elevation second=aspect
 I get `Rendering failed: Expecting 809x515 image but got 951x640 image`:
   File ".../gui/wxpython/core/gthread.py", line 116, in OnDone
     event.ondone(event)
   File ".../gui/wxpython/core/render.py", line 396, in OnRenderDone
     self.updateProgress.emit(layer=self.layer)
   File ".../etc/python/grass/pydispatch/signal.py", line 229, in emit
     dispatcher.send(signal=self, *args, **kwargs)
   File ".../etc/python/grass/pydispatch/dispatcher.py", line 349, in send
     **named
   File ".../etc/python/grass/pydispatch/robustapply.py", line 60, in
 robustApply
     return receiver(*arguments, **named)
   File ".../gui/wxpython/core/render.py", line 609, in ReportProgress
     self.renderDone.emit()
     **named
 robustApply
   File ".../gui/wxpython/core/render.py", line 538, in OnRenderDone
     raise GException(_("Rendering failed: %s" % msg))
 core.gcmd.GException: Rendering failed: Expecting 809x515 image but got
 951x640 image.
 This is my system (Lubuntu 14.10):
 GRASS version: 7.1.svn
 GRASS SVN revision: 65292
 Build date: 2015-05-20
 Build platform: x86_64-unknown-linux-gnu
 Python: 2.7.8
 wxPython: 3.0.0.0
 Platform: Linux-3.16.0-38-generic-x86_64-with-Ubuntu-14.10-utopic
Ticket URL: <http://trac.osgeo.org/grass/ticket/2677#comment:2>
