[GRASS-dev] [GRASS GIS] #2681: Remove legacy meaning of LOCATION variable
GRASS GIS trac at osgeo.org
Thu May 21 01:22:26 PDT 2015
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  task        |     Status:  new
  Priority:  blocker     |  Milestone:  8.0.0
 Component:  Startup     |    Version:  svn-trunk
Resolution:              |   Keywords:  init, grass.py, interface, CLI,
       CPU:              |  environment variables
  Unspecified            |   Platform:  All
Comment (by glynn):
 Replying to [comment:2 wenzeslaus]:
 > There is some export somewhere even now. I can do:
 GRASS > echo $LOCATION
 .../grassdata/nc_spm_08_grass7/user1
 > It seems that [source:grass/trunk/lib/init/grass.py#L1421
 bash_startup()] is to blame.
 There is no export. LOCATION is a shell variable, not an environment
 variable.
 > So then I would say that if #2679 functionality will be implemented
 (rather then dropped)
 I see no reason to implement it. And if it is implemented, the startup
 script should explicitly remove those variables from the environment.
 > This would leave the "gisrc" file the only occurrence of LOCATION_NAME
 That's already the case.
 > What we could do for 7 series is to introduce forward compatibility and
 provide `LOCATION` as an alternative for `LOCATION_NAME`. This would
 require changes to `g.gisenv` and related library functions but it seems
 possible (although I haven't checked source code yet).
 Unless you're going to make g.gisenv automatically map LOCATION to
 LOCATION_NAME, it would require changes to anything which uses it (e.g.
 lib/python/script and a number of scripts).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2681#comment:3>
