[GRASS-dev] [GRASS GIS] #2683: grass 7 doesn't start in text mode on CentOS 7
trac at osgeo.org
Thu May 21 06:18:38 PDT 2015
Reporter: morenocomelli | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
I'm trying to start grass 7 on CentOS 7 in text mode (Grass 6.4.4
installed via yum works correctly).
On Centos with GUI:
# grass70 -text
ERROR: Unable to start GRASS. You can:
- Launch GRASS with '-gui' switch (`grass70 -gui`)
- Create manually GISRC file (/root/.grass7/rc)
- Launch GRASS with path to the location/mapset as an argument (`grass70
/path/to/location/mapset`)
Exiting...
On CentOS without GUI:
# grass70 -text
WARNING: Searched for a web browser, but none found
Exiting...
#grass70
Starting GRASS GIS...
WARNING: It appears that the X Windows system is not active.
A graphical based user interface is not supported.
Switching to text based interface mode.
Hit RETURN to continue
ERROR: Path '/home/download/grass-7.0.0/<UNKNOWN>/<UNKNOWN>' doesn't exist
Exiting...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2683>
