[GRASS-dev] [GRASS GIS] #2680: d.mon: input file has incorrect dimensions
GRASS GIS trac at osgeo.org
Thu May 21 13:04:26 PDT 2015
  Reporter:  annakrat     |      Owner:  martinl
      Type:  defect       |     Status:  assigned
  Priority:  normal       |  Milestone:  7.1.0
 Component:  Display      |    Version:  svn-trunk
Resolution:               |   Keywords:  d.mon
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by martinl):
 Replying to [ticket:2680 annakrat]:
 > 1. When I resize the d.mon window, and run a d.* command, I get error:
 > ERROR: Cairo: input file has incorrect dimensions: expected: 640x480
 got:
 >        861x480
 this issue should be fixed in r65303.
 > 2. On Windows, this is even more interesting. I open wx0 monitor, run
 for example d.rast, so far good, but the second d command fails (but the
 window is still the same as when it opened):
 Let's wait for next build if it helps.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2680#comment:2>
