[GRASS-dev] [GRASS GIS] #2684: i.segment do not recycle IDnumbers (categories)
trac at osgeo.org
Fri May 22 03:28:37 PDT 2015
Reporter: franziskabeau | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Default | Version: 7.0.0
Resolution: | Keywords:
CPU: x86-64 | Platform: MSWindows 7
Comment (by mlennert):
Replying to [ticket:2684 franziskabeau]:
> Hello,
> I have the problem, that I can't export segmentationresults into
geotiff.
> The following ERROR occurs:
> ERROR 6: SetColorTable() only supported for Byte or UInt16
> bands in TIFF format.
> Warning 1: Lost metadata writing to GeoTIFF ... too large to
> fit in tag.
> Using GDAL data type <Int32>
> Exporting raster data to GTiff format...
> WARNING: Too many values, color table cut to 65535 entries
The error is only related to the color table, not the actual data. Are you
sure the export didn't work ? Try to run gdalinfo on the resulting tif
file or reimporting it into GRASS GIS or another program.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2684#comment:1>
