[GRASS-dev] [GRASS GIS] #2684: i.segment do not recycle IDnumbers (categories)
trac at osgeo.org
Fri May 22 05:57:28 PDT 2015
Reporter: franziskabeau | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Default | Version: 7.0.0
Resolution: | Keywords:
CPU: x86-64 | Platform: MSWindows 7
Comment (by franziskabeau):
Thank you for promptly answering. I really often tried over a couple of
days to export and import the generated data from GRASS-GIS to QGIS, but
it doesn´t work. I tried all the suggestions from the rasterexport-help-
box. But the ERROR information, that the color table cuts (see above)
includes, that it doesn't generate an geotiff at all. If I use the
function r.clump bevor exporting, it generates an geotiff. But this
geotiff is in a way not stabil, it desappeares as seen in the annex.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2684#comment:2>
