[GRASS-dev] Fwd: [SAC] OSGeo "tracsvn" VM down
Nikos Alexandris nik at nikosalexandris.net
Sat May 23 06:36:11 PDT 2015
@Martin,
was there recently a kernel update to the (Gentoo-)host? If yes, from my
minorest experience, it's not uncommon to have to ensure that the newer kernel
has been configured with support for specific modules (obviously,
related to KVM) or it is necesary to re-compile some modules (again,
obviously) related to KVM.
Nikos
* Markus Neteler <neteler at osgeo.org> [2015-05-23 12:56:34 +0200]:
> FYI - work in progress but it probably depends on the sysadmins who
> host the OSGeo infrastructure.
> Anyone with Gentoo and KVM is welcome to help Martin Spott.
> Markus
> ---------- Forwarded message ----------
> From: Martin Spott <Martin.Spott at mgras.net>
> Date: Sat, May 23, 2015 at 12:34 PM
> Subject: [SAC] OSGeo "tracsvn" VM down
> To: support at osuosl.org
> Cc: System Administration Committee Discussion/OSGeo <sac at lists.osgeo.org>
> Hi,
> I wonder how to restart the "tracsvn.osgeo.osuosl.org" VM on the
> "osgeo3" from command line.
> We found out that the VM is down but the Ganeti Web Manager told me it
> was running. But apparently it was unavailable (no HTTP, no SSH, no
> ping).
> I called an "immediate shutdown" of the VM in order to get into a
> consistent state. After calling a subsequent "start" in the Ganetí Web
> Manager I was told:
> "Error checking bridges on destination node 'osgeo3.osuosl.bak': Error
> 60: SSL certificate problem: certificate has expired"
> I do have access to the physical "osgeo3" machine but I have no idea on
> how to start KVM guests on Gentoo (many KVM support pages recommend
> "virsh", but there's no such command on "osgeo3").  I found a nice Wiki
> page:
>   http://www.linux-kvm.org/page/KvmOnGentoo
> ....  which says:
> "there are no standard Gentoo way to do this, you will need 3rd party
> scripts/front-ends"
> I tried to put the Ganeti utilities into well-defined state (as a test
> balloon for rebooting the entire machine) by restarting
> "/etc/init.d/ganeti" but ended up in:
> " * Starting ganeti-masterd ...
>   * exit code 1   [ !! ]"
> Please help me start this VM, I don't want to reboot the entire host
> just to start a single VM.
> Thanks,
>         Martin.
>  Unix _IS_ user friendly - it's just selective about who its friends are !
> Sac mailing list
> Sac at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/sac
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Nikos Alexandris | Remote Sensing Scientist, Dr
Themidos 3, 42100, Trikala, Greece
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
