[GRASS-dev] [GRASS GIS] #2349: CELL raster format: make ZLIB level 3 standard compression instead of RLE
trac at osgeo.org
Mon May 25 14:17:44 PDT 2015
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: critical | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: compression, r.compress, null
CPU: Unspecified | Platform: All
Comment (by neteler):
Replying to [comment:27 glynn]:
> Ultimately we need something which will just update the null file,
probably an enhancement to r.null.
Yes - this approach would save quite some CPU time.
> Note that, at present, "r.null -c" or "r.support -n" will generate a
broken map if GRASS_COMPRESS_NULLS is set, as they will write compressed
data to the null2 file but won't write the row pointers.
> Actually, those modules are already on shaky ground because they're
passing an invalid map index as the "fd" parameter to
Rast!__write_null_bits().
I hope you are willing to implement this, looking forward to it. Thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2349#comment:28>
