[GRASS-dev] [BUG] or at least unclear error message
Rainer M Krug
Rainer at krugs.de
Mon Nov 2 02:50:05 PST 2015
Hi
OS: OS X, El Capitan, grass installed via homebrew.
I have a mega location with 532 read-only mapsets with each around 2500 mapsets
(plus PERMANENT and an read-write analysis mapset).
When using g.list type=rast mapset=* I get the following error: "Unable
to open directory". I guess this is caused by to many open files as I
can execute the command g.list type=rast mapset=... for this mapset
without problems.
(transcript below)
Is this the case? Could the error message be clarified (I fear not) or a
different approach be used to list the maps?
Thanks,
Rainer
| simASM:grassAnalysis> g.list type=rast mapset=*
| ERROR: Unable to open directory
| /Users/rainerkrug/grassdata/simASM/simASM.CapePeninsula.Past.CapePeninsula_0_1.CapePeninsula.47712.2/cell
| simASM:grassAnalysis> g.list type=rast mapset=simASM.CapePeninsula.Past.CapePeninsula_0_1.CapePeninsula.47712.2 | wc -l
| 2615
| simASM:grassAnalysis> g.version -b -r -e --v
| GRASS 7.0.1 (2015)
| ./configure --prefix=/usr/local/Cellar/grass-70/7.0.1 --disable-debug --disable-dependency-tracking --enable-shared --with-cxx --with-python --with-blas --with-lapack --with-sqlite --with-odbc --with-geos=/usr/local/opt/geos/bin/geos-config --with-proj-share=/usr/local/opt/proj/share/proj --with-png --with-readline-includes=/usr/local/opt/readline/include --with-readline-libs=/usr/local/opt/readline/lib --with-readline --with-nls-includes=/usr/local/opt/gettext/include --with-nls-libs=/usr/local/opt/gettext/lib --with-nls --with-freetype --without-tcltk --with-includes=/usr/local/opt/gettext/include --with-wxwidgets=/usr/local/opt/wxmac/bin/wx-config --enable-64bit --with-macos-archs=x86_64 --with-cairo-includes=/usr/local/opt/cairo/include/cairo --with-cairo-libs=/usr/local/opt/cairo/lib --with-cairo --with-postgres --with-mysql-includes=/usr/local/opt/mysql/include/mysql --with-mysql-libs=/usr/local/opt/mysql/lib --with-mysql --with-liblas=/usr/local/opt/liblas/bin/liblas-config
| libgis Revision: 64733
| libgis Date: 2015-02-25 01:56:29 +0100 (Wed, 25 Feb 2015)
| PROJ.4: 4.9.1
| GDAL/OGR: 1.11.2
| GEOS: 3.4.2
| SQLite: 3.8.11.1
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151102/fd1daea6/attachment.sig>
