[GRASS-dev] [BUG] or at least unclear error message
Rainer M Krug
Rainer at krugs.de
Mon Nov 2 07:55:04 PST 2015
Markus Neteler <neteler at osgeo.org> writes:
> On Mon, Nov 2, 2015 at 11:50 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Hi
>> OS: OS X, El Capitan, grass installed via homebrew.
>> I have a mega location with 532 read-only mapsets with each around 2500 mapsets
>> (plus PERMANENT and an read-write analysis mapset).
>> When using g.list type=rast mapset=* I get the following error: "Unable
>> to open directory". I guess this is caused by to many open files as I
>> can execute the command g.list type=rast mapset=... for this mapset
>> without problems.
> You likely hit the current setting of open files. See e.g. this page
> how to set a higher limit:
> https://grass.osgeo.org/grass70/manuals/r.series.html#management-of-open-file-limits
Yes - that solved the issue. But I am wondering, if it really is
necessary to keep all these files open just to list the maps?
Thanks,
Rainer
> Please let us know how it goes.
> Markus
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151102/88ededda/attachment.sig>
