[GRASS-dev] [BUG] or at least unclear error message
Rainer M Krug
Rainer at krugs.de
Tue Nov 3 04:09:50 PST 2015
Glynn Clements <glynn at gclements.plus.com> writes:
> Rainer M Krug wrote:
>> I have a mega location with 532 read-only mapsets with each around 2500 mapsets
>> (plus PERMANENT and an read-write analysis mapset).
>> When using g.list type=rast mapset=* I get the following error: "Unable
>> to open directory". I guess this is caused by to many open files as I
>> can execute the command g.list type=rast mapset=... for this mapset
>> without problems.
>> (transcript below)
>> Is this the case? Could the error message be clarified (I fear not) or a
>> different approach be used to list the maps?
> G_ls2() doesn't call closedir() when it has finished reading the
> directory.
> Fixed in trunk with r66719.
Thanks.
I assume this will not be included in 7.0.2?
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151103/9cff4c18/attachment.sig>
