[GRASS-dev] testsuite: some broken tests in pygrass and python script lib
Markus Neteler
neteler at osgeo.org
Tue Nov 3 09:18:17 PST 2015
Hi devs:
any suggestions how to fix those here properly?
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-11-02-08-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/lib/python/script/test_start_command_functions_nc/index.html
File "lib/python/script/testsuite/test_start_command_functions_nc.py",
line 32, in test_prefixed_underscore
msg="Underscore as prefix was not accepted")
AssertionError: Underscore as prefix was not accepted
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-11-02-08-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/lib/python/pygrass/test_doctests/index.html
File "etc/python/grass/pygrass/utils.py", line 230, in
grass.pygrass.utils.get_raster_for_points
AttributeError: 'VectorTopo' object has no attribute 'table'
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-11-02-08-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/lib/python/pygrass/modules/grid/test_doctests/index.html
AssertionError: Failed doctest test for
grass.pygrass.modules.shortcuts.MetaModule
File "etc/python/grass/pygrass/modules/shortcuts.py", line 28, in
Failed example:
g_list.outputs.stdout # doctest: +ELLIPSIS
Expected:
'...basin...soils...'
Got:
'gmted2010\ngmted2010.shade\nlandsat.blue\nlandsat.green\nlandsat.red\nlst_2010_01_average_piemonte\nlst_2010_02_average_piemonte\nlst_2010_03_average_piemonte\nlst_2010_04_average_piemonte\nlst_2010_05_average_piemonte\nlst_2010_06_average_piemonte\nlst_2010_07_average_piemonte\nlst_2010_08_average_piemonte\nlst_2010_09_average_piemonte\nlst_2010_10_average_piemonte\nlst_2010_11_average_piemonte\nlst_2010_12_average_piemonte\norbassano_orto.blue\norbassano_orto.green\norbassano_orto.red\norbassano_orto.rgb\nsrtm\nsrtm_grezzo\nuso_suolo2007\n'
thanks
Markus
