[GRASS-dev] [GRASS GIS] #2791: GridModule error and modified SEARCH PATH
GRASS GIS trac at osgeo.org
Tue Nov 3 11:03:49 PST 2015
 Reporter:  annakrat    |      Owner:  grass-dev@…
     Type:  defect      |     Status:  new
 Priority:  normal      |  Milestone:  7.1.0
Component:  PyGRASS     |    Version:  svn-trunk
 Keywords:  GridModule  |        CPU:  All
 Platform:  Linux       |
 When using GridModule, I am getting error:
 ----> 1 grd.run()
 /usr/lib/grass70/etc/python/grass/pygrass/modules/grid/grid.py in
 run(self, patch, clean)
     530         if self.debug:
     531             for wrk in self.get_works():
 --> 532                 cmd_exe(wrk)
     533         else:
     534             pool = mltp.Pool(processes=self.processes)
 cmd_exe(args)
     344     """
     345     bbox, mapnames, gisrc_src, gisrc_dst, cmd, groups = args
 --> 346     src, dst = get_mapset(gisrc_src, gisrc_dst)
     347     env = os.environ.copy()
     348     env['GISRC'] = gisrc_dst
     139     src = Mapset(msrc, lsrc, gsrc)
     140     dst = Mapset(mdst, ldst, gdst)
 --> 141     visible = [m for m in src.visible]
     142     visible.append(src.name)
     143     dst.visible.extend(visible)
 /usr/lib/grass70/etc/python/grass/pygrass/gis/__init__.py in
 __iter__(self)
     383
     384     def __iter__(self):
 --> 385         for mapset in self.read():
     386             yield mapset
     387
 /usr/lib/grass70/etc/python/grass/pygrass/gis/__init__.py in read(self)
     393                 return [l.strip() for l in lines]
     394         lns = ['PERMANENT', ]
 --> 395         self.write(lns)
     396         return lns
     397
 AttributeError: 'VisibleMapset' object has no attribute 'write'
 This happens probably when the SEARCH_PATH is not defined in the mapset.
 Also, If I then set it and run successfully the process in parallel, the
 search path is changed, it includes all the mapsets in that location,
 which shouldn't happen.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2791>
