[GRASS-dev] Error reading raster data for row xxx (only when using r.series and t.rast.series)
Tue Nov 3 18:24:36 PST 2015
Markus Neteler wrote:
> > At a minimum, I may change the thread pool code (lib/gis/worker.c) so
> > that the default number of workers (if WORKERS isn't set) is zero,
> > i.e. multiple threads will only be used if specifically requested by
> > the user.
> Maybe better since this question came up a few times.
Done in r66731.
