[GRASS-dev] problem with manual page display: wx.Yield() called recursively
Yann
ychemin at gmail.com
Wed Nov 4 04:53:25 PST 2015
Hi Markus,
Thanks, looking into it now.
Yann
On 04/11/2015 12:04, Markus Neteler wrote:
> On Wed, Nov 4, 2015 at 11:23 AM, Yann <ychemin at gmail.com> wrote:
>> Hi,
>> I am trying to read the manual of this addon (i.spec.sam in
>> grass-addons/grass7/imagery/) from the GUI and it does not show any content.
> Hi Yann,
> the bug is this: the main.c is missing the corresponding part of the
> next lines (this is the code of i.spec.unmix):
> module = G_define_module();
> G_add_keyword(_("imagery"));
> G_add_keyword(_("spectral unmixing"));
> module->description =
> _("Performs Spectral mixture analysis of satellite/aerial images");
> I suggest that you sync the parser part to i.spec.umix (different
> descriptions of course).
> Please also add in main.c after
> #include <grass/config.h>
> these lines:
> #ifndef HAVE_LIBBLAS
> #error GRASS is not configured with BLAS
> #endif
> #ifndef HAVE_LIBLAPACK
> #error GRASS is not configured with LAPACK
> #endif
> Another small issue:
> main.c:174:44: warning: '/*' within block comment [-Wcomment]
> /*b = v_get(A->m); /* dimension of
> vector = matrix size = Ref.nfiles*/
> thanks
> Markus
Yann Chemin
Address: 3 Toul Melin, 56400 Plumergat
Mobile: +33 (0)7 83 85 52 34
