[GRASS-dev] Some wxPython 3 issues
Markus Neteler
neteler at osgeo.org
Sun Nov 8 14:32:31 PST 2015
On Mon, Nov 2, 2015 at 7:50 AM, Markus Neteler <neteler at osgeo.org> wrote:
> For the record: I opened a ticket also for that.
> https://bugzilla.redhat.com/show_bug.cgi?id=1268615
> ... which got picked up:
> --- Comment #3 from Scott Talbert <swt at XXXX> ---
> Investigated. Looks to be a wxWidgets issue - the
> wxRendererNative::DrawCheckBox() function doesn't seem to actually draw the
> checkbox when in the checked state. Reported upstream:
> http://trac.wxwidgets.org/ticket/17240
> and immediately fixed there.
> Now I expect that it will be backported to Fedora and an update shipped.
This has happened today.
> Other affected distros may do the same, so if one of you has the same
> issue, you may point them to wxWidgets bug#17240.
In Fedora solved in wxGTK3-3.0.2-11. Buttons look fine again.
Markus
