[GRASS-dev] [GRASS GIS] #2795: v.krige fails to launch from wxgui menu if a vector map is selected
GRASS GIS trac at osgeo.org
Tue Nov 10 22:16:53 PST 2015
 Reporter:  marisn       |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:
Component:  wxGUI        |    Version:  svn-trunk
 Keywords:  v.krige      |        CPU:  Unspecified
 Platform:  Unspecified  |
 If in wxgui a vector map is selected and one starts v.krige from menu, the
 name of vector map is passed to v.krige as an argument for G_OPT_V_INPUT.
 As v.krige is using grass.parser to parse input, it causes failure as
 other required parameters are not set (G_OPT_DB_COLUMN).
 wxgui gurus - no idea how to fix, as v.krige is using custom GUI dialog
 and thus just displaying standard grass.parser UI is not a solution.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2795>
