[GRASS-dev] [GRASS-SVN] r66774 - grass-addons/grass7/imagery/i.segment.stats
Moritz Lennert
mlennert at club.worldonline.be
Wed Nov 11 06:42:49 PST 2015
On 09/11/15 15:45, Vaclav Petras wrote:
> On Mon, Nov 9, 2015 at 8:52 AM, <svn_grass at osgeo.org
> <mailto:svn_grass at osgeo.org>> wrote:
> Author: mlennert
> Date: 2015-11-09 05:52:29 -0800 (Mon, 09 Nov 2015)
> New Revision: 66774
> Modified:
> grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
> <http://i.segment.stats.py>
> Log:
> clumped map is a raster, not a vector
> Modified:
> --- grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
> <http://i.segment.stats.py> 2015-11-09 12:06:44 UTC (rev 66773)
> +++ grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
> <http://i.segment.stats.py> 2015-11-09 13:52:29 UTC (rev 66774)
> @@ -82,8 +82,8 @@
> if grass.find_file(temporary_vect, element='vector')['name']:
> grass.run_command('g.remove', flags='f', type_='vector',
> name=temporary_vect, quiet=True)
> - if grass.find_file(temporary_clumped_rast,
> - grass.run_command('g.remove', flags='f', type_='vector',
> + if grass.find_file(temporary_clumped_rast,
> element='raster')['name']:
> + grass.run_command('g.remove', flags='f', type_='raster',
> I'm pretty sure that find_file wants cell for rasters (regardless of
> type). Does this work for you?
> https://trac.osgeo.org/grass/changeset/66774
> https://grass.osgeo.org/grass71/manuals/libpython/_modules/script/core.html#find_file
Actually, for me it does seem to work (because of the alias in
etc/element_list ?), but I changed it to cell anyhow.
Thanks for the heads up !
Moritz
