[GRASS-dev] [GRASS-SVN] r66772 - in grass/trunk: db/drivers db/drivers/dbf db/drivers/mysql db/drivers/odbc db/drivers/ogr db/drivers/postgres db/drivers/sqlite lib/db/dbmi_driver lib/db/stubs
Martin Landa
landa.martin at gmail.com
Wed Nov 11 08:14:53 PST 2015
2015-11-11 16:52 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
> fyi, it seems that it broke travis builds [1]. Ma
> add_col.c:2:27: fatal error: grass/dbstubs.h: No such file or directory
> compilation terminated.
> [1] https://s3.amazonaws.com/archive.travis-ci.org/jobs/90543352/log.txt
it's also broken on my pc, can anybody confirm it?
execute.c:2:27: fatal error: grass/dbstubs.h: No such file or directory
../../../include/Make/Compile.make:32: recipe for target
'OBJ.x86_64-unknown-linux-gnu/execute.o' failed
make[4]: *** [OBJ.x86_64-unknown-linux-gnu/execute.o] Error 1
make[4]: Leaving directory '/opt/src/grass_trunk/lib/db/stubs'
Martin
>> -/* this file was automatically generated by ../mk_dbdriver_h.sh */
>> #ifndef DBDRIVER_H
>> #define DBDRIVER_H
>> #include <grass/dbstubs.h>
>> -int db__driver_create_table();
>> -int db__driver_close_cursor();
>> -int db__driver_open_database();
>> -int db__driver_close_database();
>> -int db__driver_describe_table();
>> -int db__driver_init();
>> -int db__driver_finish();
>> -int db__driver_execute_immediate();
>> -int db__driver_fetch();
>> -int db__driver_get_num_rows();
>> -int db__driver_list_tables();
>> -int db__driver_open_select_cursor();
>> #define init_dbdriver() do{\
>> db_driver_create_table = db__driver_create_table;\
>> db_driver_close_cursor = db__driver_close_cursor;\
>> Deleted: grass/trunk/db/drivers/mk_dbdriver_h.sh
>> --- grass/trunk/db/drivers/mk_dbdriver_h.sh 2015-11-09 03:44:28 UTC (rev 66771)
>> +++ grass/trunk/db/drivers/mk_dbdriver_h.sh 2015-11-09 11:47:38 UTC (rev 66772)
>> @@ -1,31 +0,0 @@
>> -#!/bin/sh
>> -# generates dbdriver.h
>> -tmp=mk_dbdriver_h.tmp.$$
>> -cat <<'EOT'> dbdriver.h
>> -#ifndef DBDRIVER_H
>> -#define DBDRIVER_H
>> -#include <grass/dbstubs.h>
>> -EOT
>> -grep -h '^\( *int *\)\?db__driver' *.c | sed \
>> - -e 's/^\( *int *\)*/int /' \
>> - -e 's/ *(.*$/();/' > $tmp
>> -cat $tmp >> dbdriver.h
>> -cat <<'EOT' >> dbdriver.h
>> -#define init_dbdriver() do{\
>> -EOT
>> -sed 's/^int *db__\([a-zA-Z_]*\).*$/db_\1 = db__\1;\\/' $tmp >> dbdriver.h
>> -cat <<'EOT'>> dbdriver.h
>> -}while(0)
>> -#endif
>> -EOT
>> -rm $tmp
>> Modified: grass/trunk/db/drivers/mysql/dbdriver.h
>> --- grass/trunk/db/drivers/mysql/dbdriver.h 2015-11-09 03:44:28 UTC (rev 66771)
>> +++ grass/trunk/db/drivers/mysql/dbdriver.h 2015-11-09 11:47:38 UTC (rev 66772)
>> @@ -1,25 +1,8 @@
>> #ifndef DBDRIVER_H
>> #define DBDRIVER_H
>> -int db__driver_begin_transaction();
>> -int db__driver_commit_transaction();
>> -int db__driver_create_index();
>> Modified: grass/trunk/db/drivers/odbc/dbdriver.h
>> --- grass/trunk/db/drivers/odbc/dbdriver.h 2015-11-09 03:44:28 UTC (rev 66771)
>> +++ grass/trunk/db/drivers/odbc/dbdriver.h 2015-11-09 11:47:38 UTC (rev 66772)
>> @@ -1,24 +1,8 @@
>> #ifndef DBDRIVER_H
>> #define DBDRIVER_H
>> -int db__driver_list_databases();
>> -int db__driver_drop_table();
>> Modified: grass/trunk/db/drivers/ogr/dbdriver.h
>> --- grass/trunk/db/drivers/ogr/dbdriver.h 2015-11-09 03:44:28 UTC (rev 66771)
>> +++ grass/trunk/db/drivers/ogr/dbdriver.h 2015-11-09 11:47:38 UTC (rev 66772)
>> @@ -1,21 +1,8 @@
>> #ifndef DBDRIVER_H
>> #define DBDRIVER_H
>> db_driver_open_database = db__driver_open_database;\
>> Modified: grass/trunk/db/drivers/postgres/dbdriver.h
>> --- grass/trunk/db/drivers/postgres/dbdriver.h 2015-11-09 03:44:28 UTC (rev 66771)
>> +++ grass/trunk/db/drivers/postgres/dbdriver.h 2015-11-09 11:47:38 UTC (rev 66772)
>> @@ -1,30 +1,8 @@
>> #ifndef DBDRIVER_H
>> #define DBDRIVER_H
>> -int db__driver_create_database();
>> -int db__driver_delete_database();
>> -int db__driver_grant_on_table();
>> Modified: grass/trunk/db/drivers/sqlite/dbdriver.h
>> --- grass/trunk/db/drivers/sqlite/dbdriver.h 2015-11-09 03:44:28 UTC (rev 66771)
>> +++ grass/trunk/db/drivers/sqlite/dbdriver.h 2015-11-09 11:47:38 UTC (rev 66772)
>> @@ -1,29 +1,8 @@
>> #ifndef DBDRIVER_H
>> #define DBDRIVER_H
>> Modified: grass/trunk/lib/db/dbmi_driver/dbstubs.h
>> --- grass/trunk/lib/db/dbmi_driver/dbstubs.h 2015-11-09 03:44:28 UTC (rev 66771)
>> +++ grass/trunk/lib/db/dbmi_driver/dbstubs.h 2015-11-09 11:47:38 UTC (rev 66772)
>> @@ -1,102 +1,102 @@
>> -/* this file was automatically generated by mk_dbstubs_h.sh */
>> #ifndef DBSTUBS_H
>> #define DBSTUBS_H
>> +extern int db__driver_add_column(dbString *, dbColumn *);
>> +extern int db__driver_bind_update(dbCursor *);
>> +extern int db__driver_close_cursor(dbCursor *);
>> +extern int db__driver_close_database(void);
>> +extern int db__driver_create_index(dbIndex *);
>> +extern int db__driver_create_table(dbTable *);
>> +extern int db__driver_create_database(dbHandle *);
>> +extern int db__driver_delete(dbCursor *);
>> +extern int db__driver_delete_database(dbHandle *);
>> +extern int db__driver_describe_table(dbString *, dbTable **);
>> +extern int db__driver_drop_column(dbString *, dbString *);
>> +extern int db__driver_drop_index(dbString *);
>> +extern int db__driver_drop_table(dbString *);
>> +extern int db__driver_execute_immediate(dbString *);
>> +extern int db__driver_fetch(dbCursor *, int, int *);
>> +extern int db__driver_find_database(dbHandle *, int *);
>> +extern int db__driver_finish(void);
>> +extern int db__driver_init(int, char **);
>> +extern int db__driver_insert(dbCursor *);
>> +extern int db__driver_list_indexes(dbString *, dbIndex **, int *);
>> +extern int db__driver_list_tables(dbString **, int *, int);
>> +extern int db__driver_list_databases(dbString *, int, dbHandle **, int *);
>> +extern int db__driver_open_insert_cursor(dbCursor *);
>> +extern int db__driver_open_select_cursor(dbString *, dbCursor *, int);
>> +extern int db__driver_open_update_cursor(dbString *, dbString *, dbCursor *, int);
>> +extern int db__driver_open_database(dbHandle *);
>> +extern int db__driver_grant_on_table(dbString *, int, int);
>> +extern int db__driver_get_num_rows(dbCursor *);
>> +extern int db__driver_begin_transaction(void);
>> +extern int db__driver_commit_transaction(void);
>> +extern int db__driver_update(dbCursor *);
>> #ifdef DB_DRIVER_C
>> -extern int db__driver_add_column();
>> -extern int db__driver_bind_update();
>> -extern int db__driver_close_cursor();
>> -extern int db__driver_close_database();
>> -extern int db__driver_create_index();
>> -extern int db__driver_create_table();
>> -extern int db__driver_create_database();
>> -extern int db__driver_delete();
>> -extern int db__driver_delete_database();
>> -extern int db__driver_describe_table();
>> -extern int db__driver_drop_column();
>> -extern int db__driver_drop_index();
>> -extern int db__driver_drop_table();
>> -extern int db__driver_execute_immediate();
>> -extern int db__driver_fetch();
>> -extern int db__driver_find_database();
>> -extern int db__driver_finish();
>> -extern int db__driver_init();
>> -extern int db__driver_insert();
>> -extern int db__driver_list_indexes();
>> -extern int db__driver_list_tables();
>> -extern int db__driver_list_databases();
>> -extern int db__driver_open_insert_cursor();
>> -extern int db__driver_open_select_cursor();
>> -extern int db__driver_open_update_cursor();
>> -extern int db__driver_open_database();
>> -extern int db__driver_grant_on_table();
>> -extern int db__driver_get_num_rows();
>> -extern int db__driver_begin_transaction();
>> -extern int db__driver_commit_transaction();
>> -extern int db__driver_update();
>> -int (*db_driver_add_column) () = db__driver_add_column;
>> -int (*db_driver_bind_update) () = db__driver_bind_update;
>> -int (*db_driver_close_cursor) () = db__driver_close_cursor;
>> -int (*db_driver_close_database) () = db__driver_close_database;
>> -int (*db_driver_create_index) () = db__driver_create_index;
>> -int (*db_driver_create_table) () = db__driver_create_table;
>> -int (*db_driver_create_database) () = db__driver_create_database;
>> -int (*db_driver_delete) () = db__driver_delete;
>> -int (*db_driver_delete_database) () = db__driver_delete_database;
>> -int (*db_driver_describe_table) () = db__driver_describe_table;
>> -int (*db_driver_drop_column) () = db__driver_drop_column;
>> -int (*db_driver_drop_index) () = db__driver_drop_index;
>> -int (*db_driver_drop_table) () = db__driver_drop_table;
>> -int (*db_driver_execute_immediate) () = db__driver_execute_immediate;
>> -int (*db_driver_fetch) () = db__driver_fetch;
>> -int (*db_driver_find_database) () = db__driver_find_database;
>> -int (*db_driver_finish) () = db__driver_finish;
>> -int (*db_driver_init) () = db__driver_init;
>> -int (*db_driver_insert) () = db__driver_insert;
>> -int (*db_driver_list_indexes) () = db__driver_list_indexes;
>> -int (*db_driver_list_tables) () = db__driver_list_tables;
>> -int (*db_driver_list_databases) () = db__driver_list_databases;
>> -int (*db_driver_open_insert_cursor) () = db__driver_open_insert_cursor;
>> -int (*db_driver_open_select_cursor) () = db__driver_open_select_cursor;
>> -int (*db_driver_open_update_cursor) () = db__driver_open_update_cursor;
>> -int (*db_driver_open_database) () = db__driver_open_database;
>> -int (*db_driver_grant_on_table) () = db__driver_grant_on_table;
>> -int (*db_driver_get_num_rows) () = db__driver_get_num_rows;
>> -int (*db_driver_begin_transaction) () = db__driver_begin_transaction;
>> -int (*db_driver_commit_transaction) () = db__driver_commit_transaction;
>> -int (*db_driver_update) () = db__driver_update;
>> +int (*db_driver_add_column) (dbString *, dbColumn *) = db__driver_add_column;
>> +int (*db_driver_bind_update) (dbCursor *) = db__driver_bind_update;
>> +int (*db_driver_close_cursor) (dbCursor *) = db__driver_close_cursor;
>> +int (*db_driver_close_database) (void) = db__driver_close_database;
>> +int (*db_driver_create_index) (dbIndex *) = db__driver_create_index;
>> +int (*db_driver_create_table) (dbTable *) = db__driver_create_table;
>> +int (*db_driver_create_database) (dbHandle *) = db__driver_create_database;
>> +int (*db_driver_delete) (dbCursor *) = db__driver_delete;
>> +int (*db_driver_delete_database) (dbHandle *) = db__driver_delete_database;
>> +int (*db_driver_describe_table) (dbString *, dbTable **) = db__driver_describe_table;
>> +int (*db_driver_drop_column) (dbString *, dbString *) = db__driver_drop_column;
>> +int (*db_driver_drop_index) (dbString *) = db__driver_drop_index;
>> +int (*db_driver_drop_table) (dbString *) = db__driver_drop_table;
>> +int (*db_driver_execute_immediate) (dbString *) = db__driver_execute_immediate;
>> +int (*db_driver_fetch) (dbCursor *, int, int *) = db__driver_fetch;
>> +int (*db_driver_find_database) (dbHandle *, int *) = db__driver_find_database;
>> +int (*db_driver_finish) (void) = db__driver_finish;
>> +int (*db_driver_init) (int, char **) = db__driver_init;
>> +int (*db_driver_insert) (dbCursor *) = db__driver_insert;
>> +int (*db_driver_list_indexes) (dbString *, dbIndex **, int *) = db__driver_list_indexes;
>> +int (*db_driver_list_tables) (dbString **, int *, int) = db__driver_list_tables;
>> +int (*db_driver_list_databases) (dbString *, int, dbHandle **, int *) = db__driver_list_databases;
>> +int (*db_driver_open_insert_cursor) (dbCursor *) = db__driver_open_insert_cursor;
>> +int (*db_driver_open_select_cursor) (dbString *, dbCursor *, int) = db__driver_open_select_cursor;
>> +int (*db_driver_open_update_cursor) (dbString *, dbString *, dbCursor *, int) = db__driver_open_update_cursor;
>> +int (*db_driver_open_database) (dbHandle *) = db__driver_open_database;
>> +int (*db_driver_grant_on_table) (dbString *, int, int) = db__driver_grant_on_table;
>> +int (*db_driver_get_num_rows) (dbCursor *) = db__driver_get_num_rows;
>> +int (*db_driver_begin_transaction) (void) = db__driver_begin_transaction;
>> +int (*db_driver_commit_transaction) (void) = db__driver_commit_transaction;
>> +int (*db_driver_update) (dbCursor *) = db__driver_update;
>> #else
>> -extern int (*db_driver_add_column) ();
>> -extern int (*db_driver_bind_update) ();
>> -extern int (*db_driver_close_cursor) ();
>> -extern int (*db_driver_close_database) ();
>> -extern int (*db_driver_create_index) ();
>> -extern int (*db_driver_create_table) ();
>> -extern int (*db_driver_create_database) ();
>> -extern int (*db_driver_delete) ();
>> -extern int (*db_driver_delete_database) ();
>> -extern int (*db_driver_describe_table) ();
>> -extern int (*db_driver_drop_column) ();
>> -extern int (*db_driver_drop_index) ();
>> -extern int (*db_driver_drop_table) ();
>> -extern int (*db_driver_execute_immediate) ();
>> -extern int (*db_driver_fetch) ();
>> -extern int (*db_driver_find_database) ();
>> -extern int (*db_driver_finish) ();
>> -extern int (*db_driver_init) ();
>> -extern int (*db_driver_insert) ();
>> -extern int (*db_driver_list_indexes) ();
>> -extern int (*db_driver_list_tables) ();
>> -extern int (*db_driver_list_databases) ();
>> -extern int (*db_driver_open_insert_cursor) ();
>> -extern int (*db_driver_open_select_cursor) ();
>> -extern int (*db_driver_open_update_cursor) ();
>> -extern int (*db_driver_open_database) ();
>> -extern int (*db_driver_grant_on_table) ();
>> -extern int (*db_driver_get_num_rows) ();
>> -extern int (*db_driver_begin_transaction) ();
>> -extern int (*db_driver_commit_transaction) ();
>> -extern int (*db_driver_update) ();
>> +extern int (*db_driver_add_column) (dbString *, dbColumn *);
>> +extern int (*db_driver_bind_update) (dbCursor *);
>> +extern int (*db_driver_close_cursor) (dbCursor *);
>> +extern int (*db_driver_close_database) (void);
>> +extern int (*db_driver_create_index) (dbIndex *);
>> +extern int (*db_driver_create_table) (dbTable *);
>> +extern int (*db_driver_create_database) (dbHandle *);
>> +extern int (*db_driver_delete) (dbCursor *);
>> +extern int (*db_driver_delete_database) (dbHandle *);
>> +extern int (*db_driver_describe_table) (dbString *, dbTable **);
>> +extern int (*db_driver_drop_column) (dbString *, dbString *);
>> +extern int (*db_driver_drop_index) (dbString *);
>> +extern int (*db_driver_drop_table) (dbString *);
>> +extern int (*db_driver_execute_immediate) (dbString *);
>> +extern int (*db_driver_fetch) (dbCursor *, int, int *);
>> +extern int (*db_driver_find_database) (dbHandle *, int *);
>> +extern int (*db_driver_finish) (void);
>> +extern int (*db_driver_init) (int, char **);
>> +extern int (*db_driver_insert) (dbCursor *);
>> +extern int (*db_driver_list_indexes) (dbString *, dbIndex **, int *);
>> +extern int (*db_driver_list_tables) (dbString **, int *, int);
>> +extern int (*db_driver_list_databases) (dbString *, int, dbHandle **, int *);
>> +extern int (*db_driver_open_insert_cursor) (dbCursor *);
>> +extern int (*db_driver_open_select_cursor) (dbString *, dbCursor *, int);
>> +extern int (*db_driver_open_update_cursor) (dbString *, dbString *, dbCursor *, int);
>> +extern int (*db_driver_open_database) (dbHandle *);
>> +extern int (*db_driver_grant_on_table) (dbString *, int, int);
>> +extern int (*db_driver_get_num_rows) (dbCursor *);
>> +extern int (*db_driver_begin_transaction) (void);
>> +extern int (*db_driver_commit_transaction) (void);
>> +extern int (*db_driver_update) (dbCursor *);
>> #endif
>> #endif
>> Deleted: grass/trunk/lib/db/dbmi_driver/mk_dbstubs_h.sh
>> --- grass/trunk/lib/db/dbmi_driver/mk_dbstubs_h.sh 2015-11-09 03:44:28 UTC (rev 66771)
>> +++ grass/trunk/lib/db/dbmi_driver/mk_dbstubs_h.sh 2015-11-09 11:47:38 UTC (rev 66772)
>> @@ -1,29 +0,0 @@
>> -#!/bin/sh
>> -# generates dbstubs.h
>> -tmp=mk_dbstubs_h.tmp.$$
>> -cat <<'EOT'> dbstubs.h
>> -#ifndef DBSTUBS_H
>> -#define DBSTUBS_H
>> -#ifdef DB_DRIVER_C
>> -EOT
>> -grep -h '^\( *int *\)\?db__driver' ../stubs/*.c | sed \
>> - -e 's/^\( *int *\)*/extern int /' \
>> -cat $tmp >> dbstubs.h
>> -sed 's/^extern int *db__\([a-zA-Z_]*\).*$/int (*db_\1)() = db__\1;/' $tmp >> dbstubs.h
>> -cat <<'EOT'>> dbstubs.h
>> -#else
>> -EOT
>> -sed 's/^extern int *db__\([a-zA-Z_]*\).*$/extern int (*db_\1)();/' $tmp >> dbstubs.h
>> -#endif
>> -#endif
>> -EOT
>> -rm $tmp
>> Modified: grass/trunk/lib/db/stubs/open_update.c
>> --- grass/trunk/lib/db/stubs/open_update.c 2015-11-09 03:44:28 UTC (rev 66771)
>> +++ grass/trunk/lib/db/stubs/open_update.c 2015-11-09 11:47:38 UTC (rev 66772)
>> @@ -2,7 +2,7 @@
>> int
>> db__driver_open_update_cursor(dbString * name, dbString * select,
>> - dbCursor * cursor, int *mode)
>> + dbCursor * cursor, int mode)
>> db_procedure_not_implemented("db_open_update_cursor");
>> return DB_FAILED;
>> grass-commit mailing list
>> grass-commit at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-commit
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
Martin Landa
