[GRASS-dev] [GRASS GIS] #2798: v.centerline fails with real data
trac at osgeo.org
Fri Nov 13 07:57:23 PST 2015
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Addons | Version: svn-trunk
Resolution: | Keywords: v.centerline
CPU: Unspecified | Platform: Unspecified
Changes (by martinl):
* milestone: => 7.0.1
Old description:
> I tried `v.centerline` to produce center line for highways in CZ imported
> from OSM, see (1).
> v.centerline input=highway out=highway_c
> The result is one small line (red color) located somewhere in the space,
> see attachment:v-center-line.png.
> (1) http://geo102.fsv.cvut.cz/~landa/trac_attachments/highway.pack
New description:
from OSM, see (1), EPSG:5514 (you can use also 2065 if you have Proj.4
<4.9.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2798#comment:2>
