[GRASS-dev] what is the correct way to import a spatialite db into trunk?
Helmut Kudrnovsky
hellik at web.de
Wed Nov 18 13:10:41 PST 2015
given a shapefile translated to a spatialite db:
ogr2ogr -f "SQLITE" testshape.sqlite testshape.shp -dsco SPATIALITE=YES
ogrinfo testshape.sqlite -al
INFO: Open of `testshape.sqlite'
using driver `SQLite' successful.
Layer name: testshape
Geometry: Polygon
Feature Count: 1
Extent: (16.709875, 47.783588) - (16.826881, 47.911541)
Layer SRS WKT:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]]
FID Column = OGC_FID
Geometry Column = GEOMETRY
cat: Integer (0.0)
test: Integer (0.0)
OGRFeature(testshape):1
cat (Integer) = 1
test (Integer) = 1
POLYGON ((16.79321008613654 47.911540344688355,16.826880116934124
47.783594227
657538,16.709876759912522 47.784435978427481,16.79321008613654
47.91154034468835
5))
then:
v.in.ogr --ui
Source type file:
v.in.ogr -l input=C:\tmp\newaddons\testsqlite\gg\testshape.sqlite
layer=testshape|GEOMETRY
Data source <C:\tmp\newaddons\testsqlite\gg\testshape.sqlite> (format
'SQLite') contains 1 layers:
testshape
v.in.ogr input=C:\tmp\newaddons\testsqlite\gg\testshape.sqlite
layer=testshape|GEOMETRY output=t1
ERROR: Layer <testshape^^^|GEOMETRY> not available
Source type database:
=> input layer id marked, but input not reckognized
v.in.ogr input=<required> layer=testshape|GEOMETRY output=t2
GRASS version: 7.1.svn
GRASS SVN revision: 66855
Build date: 2015-11-18
Build platform: i686-pc-mingw32
GDAL: 1.11.3
PROJ.4: 4.8.0
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
let's test it in 7.0.2RC2
v.in.ogr --ui
testshape
Selection tab => not geometry column choosable
v.in.ogr input=C:\tmp\newaddons\testsqlite\gg\testshape.sqlite output=t3
Check if OGR layer <testshape> contains polygons...
Column name <cat> renamed to <cat_>
Importing 1 features (OGR layer <testshape>)...
Registering primitives...
One primitive registered
4 vertices registered
Number of nodes: 1
Finding centroids for OGR layer <testshape>...
Writing centroids...
1 input polygons
Total area: 6.21962E+007 (1 areas)
Copying features...
WARNING: Unable to delete file
'C:\grassdata/srtm41gar/test/.tmp/unknown/vector/tmp_7840/coor'
Building topology for vector map <t3 at test>...
2 primitives registered
5 vertices registered
Building areas...
One area built
One isle built
Attaching islands...
Attaching centroids...
Number of nodes: 1
Number of primitives: 2
Number of points: 0
Number of lines: 0
Number of boundaries: 1
Number of centroids: 1
Number of areas: 1
Number of isles: 1
(Wed Nov 18 22:10:06 2015) Command finished (8 sec)
any ideas to how to import a spatialite db into trunk?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/what-is-the-correct-way-to-import-a-spatialite-db-into-trunk-tp5237277.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
