[GRASS-dev] v.rast.stats fails with column_prefix='t'
Anna Petrášová
kratochanna at gmail.com
Thu Nov 19 21:10:19 PST 2015
On Thu, Nov 19, 2015 at 2:53 PM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> Nikos:
> > > The command
> > > v.rast.stats map=SomeVector raster=SomeRaster column='t'
> > > fails. Perhaps the line
> Anna:
> > How exactly does it fail?
> v.info -c Test
> INTEGER|cat
> INTEGER|Id
> CHARACTER|Name
> v.rast.stats map=Test raster=LT51960282005221KIS00_B1 column='t'
> Traceback (most recent call last):
> File
> "/osgeo/grass70/dist.x86_64-unknown-linux-gnu/scripts/v.rast.stats", line
> 306, in <module>
> main()
> File
> 268, in main
> i = variables[variable]
> KeyError: 'firsquartile'
> Strange, however, it does not fail always!?
> Another example
> v.info -c test
> INTEGER|cat
> v.rast.stats map=test raster=test column_prefix='t'
> seems to work and gives
> DOUBLE PRECISION|t_number
> DOUBLE PRECISION|t_minimum
> DOUBLE PRECISION|t_maximum
> DOUBLE PRECISION|t_range
> DOUBLE PRECISION|t_average
> DOUBLE PRECISION|t_stddev
> DOUBLE PRECISION|t_variance
> DOUBLE PRECISION|t_coeff_va
> DOUBLE PRECISION|t_sum
> DOUBLE PRECISION|t_first_qu
> DOUBLE PRECISION|t_median
> DOUBLE PRECISION|t_third_qu
> DOUBLE PRECISION|t_per90
> Nikos
Should be fixed in 66864. I still don't understand why it doesn't fail in
the other case though.
Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151120/f46a4c91/attachment.html>
